Water Puddles On Floor Under Side Air Vents!
Woolymammoth
Hi guys,
Hope you can help me, i have a 52 plate roadster and only just starting noticing there is a puddle of water on the outside floor under the road vents, its dripping off the bodywork at the bottom sill.
One week its the off side then suddenly its the near side.
I have heard water moving around when im driving around bends.
Its definately not a coolant leak its clear water. I had it mot'ed lately and had it up on a ramp and water is collecting somewhere dont know where cant see???
Do any of you guys have the same problem i take it, its a blocked drain somewhere with water coming in from the side vent or where the soft top meets the bodywork???
Hi guys,
theres a drain tube on either side of the soft top in the corner where the (what would be the b piller)door shuts
they are normally filled with leaves and other rubbish clean them and flush it with some clean water..
