Rav4 Sat Nav Dvd Update To Full Postcode
Rav4Pete
Hi Guys
have a rav4 2005 and wanting to know if the satnav now has full postcode lookup if updated, mine only has part.
thanks
I have 2008-2009 cd and I can only input the 1st part and then 1 digit on the 2nd part, is this 4 digit post code?
Hi Guys
thanks
HI
just to add the new e11 disk is still using old uk maps so I would hold out and see what the 2010 maps are like :)
edit i`ve just been playing with the E11 map & the maps might be ok (upto date)
it`s the search engine that is still crap!, for instance if you search for raleigh drive which is in laindon essex, you wont find it unless you search for it under basildon essex, which unless you know the area you would not do???.
Mind you I still think it`s better than tom tom
