Gear Box Noise
Freddie p
Hello
I wonder if any one can help me i am getting some noise from my gear box and dont know if it is cluch or gear box.The noise is a knocking noise when i change down from 4th to 3rd,3rd to 2nd and 2nd to 1st if i change gear quick the noise is minimal but if i lift the clutch slowly when canging down the noise is more consistant.There is no noise when changing up through the gears.My car is a avensis 2 liter d 4d deisel 51 plate.
Many thanks
Fred
sounds like flywheel.
What kind of miles have you done?
can the noise be heard on idle?
Thanks for your reply it has done 153,000 miles the noise is not there when it is idle only when you change down gears
