Manual Gearbox Oil: 75w/90 Vs Atf
mach3
Inputs on this one are welcome:
Is 75W/90 or ATF (Automatic Transmission Fluid) the best for a manual gearbox (in avensis T22)?
Haynes specifies it to use 75W/90 but I some cardealers use the ATF (Dexron type II or Dexron type III).
Thanks in advance.
I recommend you pay a visit to the internet car doctor (at least in my opinion) -
http://www.fixya.com/cars/toyota
Works like a charm, if you can't find your problem post one, within a day u'll have an answer.
Good luck!
Seems like you have to pay $10 at that page to get an answer :o) No thanks
"Automatic transmission fluid"
"Manual Gearbox"
The clues are in the names :)
ATF and gearbox oil are completely different things.
Gearbox oil is like engine oil but thicker.
ATF is a hydraulic fluid, like power steering or brake fluid.
They're not interchangeable!
Auto Transmission Fluid is otherwise known as Power Steering Fluid.
Its way too thin for a manual gearbox.
Some drag racers use it on the 1/4mile as it reduces tranmission loss...but it will destroy the gearbox very quickly.
