Flat Spot
MK320VT
whilst i drive the car it judders/stutters between 1000 - 1500 rpm in every gear and low on power.
then back to normal.
had the plugs changed only 1500miles..
pls help thanks
pls help thanks
is there anything i need to check??
check tb cables
HT leads, coils distributors
did u use the corret type of sparkplugs and gapped them correctly ?
purchased form dealers and got garage to install them
but will get them rechecked
