Rav 4.2 D4d Service
nattyboy
Hi All
Im getting wildly varying quotes for a 40k service on our '05 D4D. We are in Wiltshire. Does anyone know of any decent indpependents - or could you let me know what you guys ahve paid for this service and what it involves (again this is varying with some saying the gearbox oil needs replacing and some saying it doesnt ! ?)
Many Thanks
Nat
here you go
R & B MOTORS
74 CO-OPERATIVE STREET
STAFFORD STAFFORDSHIRE
ST16 3DA
Telephone : 01785 255921
Fax :
Vehicle Details
RAV4 Toyota RAV4 Car, 2.0 , Estate , Manual g/box , 5 Speed , Diesel , Inj., Turbo , 4cyl. , DOHC , 16v , 4WD , RHD , 1995 cc
Year : 2005
40000 miles Service
Inside
001 Check alarm operation
002 Check brake pedal freeplay and parking brake travel
003 Check brake pedal and servo operation - report
004 Check operation of combination meter warning lights (ignition on bulb check)
005 Check correct operation of all exterior lights
006 Check clutch for pedal clearance, operation and slipping
007 Check steering wheel freeplay, security
008 Check operation of horn, all washers and wipers
009 Check condition of windscreen
010 Check condition of seat belts and SRS airbag covers - report
011 Check air conditioning filter (where applicable)
012 Replace Battery in remote locking
013 Release fuel lid
Outside/Under Bonnet
014 Inspect all light lenses for damage and security
015 Inspect body and glass for corrosion and damage - report
016 Remove spare wheel/tyre (where applicable)
017 Check and inspect fuel cap
018 Check condition of all Wiper Blades - report
019 Check valve clearances, audibly with stethoscope (every 4 years/30,000 miles, adjustment at extra cost)
020 Check security and condition of the Battery and terminals - report
021 Check brake fluid level and condition - report
022 Top-up washer fluid
023 Check power steering fluid level
024 Check clutch fluid level and condition - report
025 Check brake and clutch master cylinder and brake servo for security and leakage
026 Check coolant level and strength - report
027 Check all visible hoses, pipes and connections for leakage and condition - report
028 Check/inspect air filter
029 Replace air filter (every 4 years/30,000 miles)
030 Check condition and security of drive belt
Vehicle Raised
031 Drain engine oil
032 Replace oil filter
033 Drain coolant (after 3 years/40,000 miles, thereafter every 2 years/20,000 miles - Long Life Coolant only, at extra cost)
034 Replace rear differential oil
035 Check and inspect exhaust system and mountings for security and leakage
036 Check and inspect fuel lines, connections and vapour control
037 Check brake (and clutch, where applicable) system pipes, hoses and connections for condition and leakage
038 Check manual transmission oil level
039 Check and inspect ball joints
040 Check and inspect driveshaft boot covers
041 Check tightness of driveshaft bolts
042 Check propshaft joint for security and tightness
043 Check front and rear suspension for security, leakage and correct operation
044 Check steering system for correct operation, security and leaks
045 Check and report on brake pads and discs
046 Check and report on brake linings and drums including handbrake drums, clean out dust - adjust as necessary
047 Check and report on tyre wear, damage - adjust pressures
048 Check general condition under the vehicle; visible leaks, excessive corrosion and damage - report
049 Full 4-wheel alignment check (adjustment at extra cost)
050 Replace brake fluid (every 2 years)
Vehicle Lowered & Final Inspection
051 Refill engine oil
052 Refill engine coolant (if applicable)
053 Replace fuel filter (every 6 years/40,000 miles, at extra cost)
054 Re-install spare wheel/tyre (where applicable)
055 Torque tighten all wheel nuts
056 Carry out diesel smoke test (every 4 years/30,000 miles)
057 Final check of all levels - top-up as necessary
058 Final inspection for leaks
Technician comments:
Technician signature:
If we did it it would come to £163.70 but the labour and parts for the antifreeze change would be more(extra cost) in srvice schedule
