Hi everyone..
Just been searching the forum for information on removing the actual wiper arm from the spindle - NOT the wiper blade from the arm - if you get me..
I've removed a cover - which reveals a little nut...I've undone that - but when trying to pull the arm off the shaft - it just wont budge!
Not one for forcing things - is there something else i need to do to get the arm off?
Matt ;)
I believe the splines on the shaft are conical AND you've got the spring pressure
of the arm working against you, pushing the attachment askew over the spindle.
It might be a good idea to unbolt the secondary arm at the blade, this should allow
you to flip up the arm entirely and might make it easier to remove the arm.
ok thanks for that - will try again tomorrow!
thanks
matt
