Carina E - Rear Foglight Switch Pins?
All,
I hit the "well known" problem of the facelifted ('96) Carina E. Its rear foglight switch is not working reliable.
I found that this switch has 8 pins.
If I replace it with Carina E earlier model's switch (made in Japan) which has 4 pins but the same connector - the foglight is working fine, but the headlight stops working. :-(
I cannot find any wiring diagram about the later model - I have Haynes manual, and it has the older japan model diagram in it. Techdok doesn't contain Carina, ToyoDIY also not has wiring diagram.
-Do you have a wiring diagram for facelifted Carina E?
-Do you know what are the 8 pins in facelifted Carina E's rear foglight switch?
-Are you aware of any methods hot to assemble the old switch into the new car, and have a working headlight?
Thank you!
