Avensis Creaking Clutch
jimtaxi
Hi all I have just had a 40000 service and my main dealer has told me that the clutch master cylinder needs replaced. This should stop the creaking of the clutch pedal when depressed. This is after 8 months of complaining about the clutch operation they noe act .!!!! keep you posted as to what happens after it has been replaced. Taxijim :(
It is a common fault on Avensis, the material the cylinder was made of has been changed ;)
Kingo :thumbsup:
I have also experience the creaking pedal. The Toyota dealer stripped down the master cylinder to clean and lubricate the internals, however, this only stopped the noise for a few weeks.
At the moment the creak is not there, however, it will probably return as soon as the weather gets colder. I think that ultimatley I will need to have the master cylinder replaced. Does anyone know the cost of the parts and labour for this?
I did get mine changed last year and it came at about £ 120 (labor and parts) give or take.
Has anybody else got the creaky steering wheel , I have had three Avensis and they have all been the same, as soon as the weather gets warmer the Wheel starts to creak when turned ? :o
Gordi, you are more likely to get answers for your questions if you start a new thread for your question.
Anyways, I had the same problem, (at least all toyotas get the same problems. precision work ey? :P ).
http://toyotaownersclub.com/forums/index.p...mp;#entry788665
its a rubber seal.
nothing to be worried of
  • 3 months later...
Car has now done 13000 since master cylinder replaced clutch operation has been normal, no creaking!! :D
Had same problem a few months ago. Took off plastic cover by clutch pedal( remove a couple of screws and unclip), sprayed with WD40 using tube to get to pushrod as irt goes through bulkhead. This only cured the creaking for a couple of weeks, so i tried spraying with silicone spray (bought from Halfords). This seems to have cured problem.
I had the creaking and just wiggled the bit of plastic in the bulkhead - it stops the creak for a while. Cold weather has silenced it too. I think silicone spray or similar will be my next choice.
Just lubed my clutch with light grease & silicone spray, all seems nice & quiet now :rolleyes: we'll see how it gets on.
