Coolant
Notebook
Hi All
Noticed the pink coolant in my rav could do with a little topping up. All the same stuff or anything I should look out for?
Should be Toyota "forlife" (Kingo might send you some) but the main thing is to top it up when stone cold to the "full" mark and then watch it carefully each day when stone cold. If it does go down or you can see any traces of coolant down the front of the engine take it in somewhere. If the water pump collapses it could make a mess of the engine.
