Help With Vss Wtgs And Wts In A Jdm St185
GT4 JDM
Hi, i have recently put a new engine in my car. I got error codes and upon looking into further found this,
First code was for water temp sensor, which has now gone away ??
Second was the water temp gauge sender. which came after the temp sensor one went. Kinda need this gauge ??? and theres nothing on the loom to connect it up to ???
Third is the vehicle speed sensor, which means i dont have a speed-o. Kind need this too.
The car has an oil leak which is tempromental ..... but i always check the radiator and oil before i drive it and there both fine. could it be gearbox oil ?
I need these things sorted so i can be sure its ok.
Any help would be great
