Obd Fault Code Connector On 51 Plate Avensis
rich  avensis
Be gentle it's my first post!
I have a 2002 registered 51 plate avensis.the engine management warning light has illuminated. I can reset it by removing fuses but it returns.
Reading this forum leads me to believe my avensis should have an obd connector to which I can connect a fault code reader!
Can I find it under the steering wheel in the drivers side of the car. No I can't - I am presuming it would be quite obvious? Any advice if either I am not looking in the right place or if my car would not have the connection appreciated!
Rich
Rich
i have a 2004 model and the obd connector is drivers side below fuses down very low there is a small cover over it.
Rich
thanks for help so far! I can't find an internal fusebox in my drivers foot area! So I am starting to think my car is too early a specification! I presume you did not need to remove any carpet or dash to find connector?
Thanks again
rich
under the steering wheel to the right u have a pocket to hold items
remove that obd reader is behind that.,
Excellent advice just where you said it was!
Error p0171 and p0174 bank 1 and 2 lean ..... Now just got to work out what to replace!
Thanks to all for help so far! Happy for advice on likely suspects for fault codes!
Rich
