Timing Belt
tesa
Hi
One other thing I wanted to ask the forum. I need to change a timing belt on the 4,1 rav4 engine (4 cylinder 2000cc ) is it the same procedure as on a corolla engine (1600cc twin cam EFI 1993) The corolla seemed quite easy to do only took about 4 hours.
The vehiche seems to have a noise either in the water pump or tensioner bearing.
thanks for your help
Tesa
The only akward bit was drivers side engine mount. The rest seemed fine and have a mirror to check the alignment of the timing mark on the camshaft.
