Celica 99-02 Oil Level Higher Than Top Of Dipstick?
Q2000
Is it true in prefacelift celicas your to overfill oil by about 5mm of max dipstick?
Im not sure if its true or not but the prefaclift vvt-i 1zzfe engines did used to suffer from high oil consumption due to the worn piston rings if i can remember rightly. So imo i would fill it up to the maximum line and just check it at least once a week to keep check on the level. :)
