Import
sillycarsally
i got a celica st202 16 valve import model. and like all imports its been restricted to like 112mph. not cool. i was wondering does anyone know how to remove this, i heard its a simple fuse but surely not. and also what are the good points and bad points to doing this. cheers
You'll need to wire in a speed limiter remover (you can buy these off ebay) or if your clocks are still in kph just get a speedo convertor. Therefore 180kph will become 180mph....doesnt remove the limiter but there is no way you'll ever hit it after the conversion..
Convertor does remove the limiter
there are 2 kinds of convertors. ;) 1 is a delimmiter , 1 is a speedo converter , some do both jobs but not all.
