Looking To Buy A Celica 190
kwaii
Hi all,
i'm new to the forum, but i am looking to buy a gen 7 celica 190, is there anything in particular which i should be looking out for?
any help or pointers much appriciated
thanks
Hi all,
thanks
Hi welcome to the forum :),
*Most important thing is to check to see that lift functions properly, as early 190's used to suffer with the lift bolts breaking if i remeber rightly,
Just your basic checks to then.
Hope this has helped :)
Lift is agressive, noticable and addictive if a little sore on the wallet. Comes in at 6,200 and takes you to 8,200. Basically +50 HP on tap over a 140.
look at the front and rear brakes the disks suffer bad from corrosion on the inner faces also look at the parcel shelf the clips in the back 1/4 snap off.also look for service history.apart from that enjoy lovely cars the wife bought the celica gt(190 with trd kit and diff seats)and she loves it.cheap to run if you dont go into lift!
Look for good service history. The way I see it if an owner hasn't serviced one of these properly they are more likely to have thrashed it. It's the type of car that encourages you to rev it hard so you want one that has been looked after.
