Engine Cuts Off Randomly
error404
hi all
have a 2003 silver Yaris (made in france) have around 80k on the clock
every so often sometimes whilst im driving either on the carraige way or streets it engine just cuts off and i have to restart to get it going again this happens like once in a while probably 1 in every 40 journeys
now last few days i have had problems starting the car..i would turn the ignition it would like kinda start then after 2 sec just like cut off after a few attempts i manage to get it working
sometime i can get it started within one attempt the others maybe after 5-6 totally random!
any ideas what the cause of this could be?
sounds like: flywheel position sensor...
can you expand on this please aswell something one can do or does it need taking to garage? is this a big job or small if indeed this is the case
i been reading around aswell could be possibly something to do with fuel filter even - forgot to mention before it cuts of it shuders!
First question.
Has it been serviced regularly? And recently?
If so by whom.
If it is the fuel filter, it is unlikely to prevent the car from starting and you are likely to see fuel starvation at high speed.
If you don't know what a flywheel (or crankshaft position ) sensor is, it's a garage job.
Fuel filter is easy DIY - if you have ever done DIY.
The shuddering can be anything...
The position sensor controls ignition timing. it is quite sensitive and the internal wires can fracture over time and thus when warm give random failures. As it gets worse, ..starting can be affected.
It could also be an immobiliser fault, or fuel starvation ...or...
First question.
If so by whom.
THANKS
l serviced it back in feb last did a full service take it to nationwide garages not serviced it since then though its due very soon
but im thinking of doing a Major Service with nationwide autocentres
http://www.nationwideautocentres.co.uk/pdf...ce_schedule.pdf
so dont know if that may help perhaps?
I've got a 2001 Yaris which was recalled for a check crankshaft monitor last year, this was done for free.
There's something online to check up on recall notices.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
