93 Celica Gt Rear Abs Rotor Removal
Scots Miss
RE Gen 5 Celica 2 lt GT ST 182 non UK import. - I have removed the unit and looked at several manuals on this but I can't see how the ABS sensor rotor is attached to the Axle stub shaft ( 2 WD) it is a very brittle steel and will easily be damaged. Can anyone explain how it is fixed - pressed in, screwed LH or RH into the stub shaft . It must be removed to be able to replace the wheel bearings?
