Where Can I Buy Eclipse Black Metallic Paint?
PhillWalker
A decent motor factors should be able to make you up a rattle can or other pot if you happen to own a compressor. Doesn't cost much.
Get the exact paint code, you might need the vehicle VIN number aswell and have a look online.
There's loads of firms that will make you an aerosol can or they can put the paint in a sealed can for you to apply with an airbrush, but you will need a compressor as mentioned by Chris81. ;)
