Auris/corolla Sideskirts
shin0bi
hey guys, i'm from australia. just recently purchased tte sideskirts from tte.de for my auris.
anyway just wondering if anyone has installed these themselves and may be able to help me out.
My problem is...as per the instruction installation sheet provided on toyota-tech.eu it says to use the glue they provide and the existing holes to fit it.
But what i noticed is that there is no hole in the rear wheel arch and skirt to keep the rear side of the skirt secured to the body apart from the glue. i was thinking of not using the glue they provided and instead just go with securing it with the clips and screws. Did anyone if any, install it without using the glue and drill a hole to secure the rear end of it?
Anyone got thoughts or can shed any light on this?
Cheers.
G/day Mate,
Login onto this web site >>>> http://techdoc.toyota-europe.com/Aim.aspx?menuitem=2
Then follow the steps below.
1/ click search AIM.
2/ click vehicle.
3/ click accessory group.
then just scroll down until you come to skirts.
Take care
Kev
G/day Mate,
2/ click vehicle.
Take care
Kev
Thanks for that kev. i knew that already. my question is if anyone installed it without using the glue and drilled a hole into the rear wheel arch..and had any problems
It mounted theese skirts on my previous auris without glue.
I used a kind of "rubber, chewing-gum type of thing"
Don`t know how to explain it, but I bought it frome 3M...
I used the clips, but had to drill a hole in the wheel arches to secure it in each end.
Did not want to use the glue in case the next owner did not want them on..
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
