Brake Pads
CALSHOT
Anyone know if you were to get some new discs ie EBC on the rear only, can you still use the existing toyota pads (as mine are only say 3mths old ish and have been driven in sparingly).
Cheers
Cheers
you can get them from eBay mate if you are going to use the old pads get some 60 grit sand paper put on a flat surface then scuff the pads till flat.
