Air Con Re Gassing Valve
djt100
Can anyone tell me where the valve is to re gas the air con on a 2000 MR2 Roadster ? I've had a look under the bonnet and boot, And can't see a thing ?? do i have to remove the big lump of plastic from the front to see the valve, Any pointers appreciated
thanks
thanks
The valve is under the bonnet and you need to remove the plastic unfortunately. The valve you are looking for is (when standing looking towards the car from the front) towards the top right hand section, just above right of the frunk storage. The valve will have a cap on it that I think has a big 'L' on it.... can't miss it!
thanks
Thankd Bridge MR2, I thought that might be the case, but wasted confirmation before i went to the trouble!.. Cheers
