Turbo Problem?
termitis
Hi guys
last night i encountered the following problem
my car is d4d.
normally you feel the turbo come in when you get the 1800 rpm onwards. you know the tug to feel after these turns.
last night for some odd reason i felt that the turbo does not work. That started with hot engine and 1st gear and arrived at 1800 rpm but nothing. Go to 2500 but still I am not feelig the pull from the turbo. I put second gear (the 2nd feels the most intense off) 1800 rpm - 2000 - 2500 but nothing. The car feels no pull . The same applies to the 3rd.
Shock and stop. I leave for 5 minutes off the car and I restart. 1st gear until 3000 rpm and the There's no turbo feel. 2nd gear with gently pulling until 3000 but no turbo or anything. Not felt and not pulling the car like it should. Then go to the 3rd speed until 3200 when suddenly the turbo ENTERED and a sharp kick felt that continued normally. Stop the car and off for no more than 20 minutes. Since then okay. As if nothing had happened. The normally feel at all speeds from 1800 rpm.
It seemed like a serious problem. someone ran something similar?
I hear opinions
My Yaris model is 2009 with 21,000 KM on the clock and abide by all the requirements for safe engine and turbo. That is, when it is cold and no sudden acceleration after a journey always leave the car idling for no 2mnts to cool the turbo
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
