Lower Bumper Fog Lights ?
Beagh1958
To all, especially Toyota-Tech's.
I have a MK11 2003 plate D4D T3s. The original owner did not request above titled spot/fog lights when purchasing car. Apart from changing headlamp switch & purchasing lights, can anybody tell me if the car wiring loom is set up for this option already. Would i just require a relay & fitment of fuse into empty slot, or is it more complicated?
Any help would be much appreciated.
Regards, Beagh.
Have a look behind the blanking plates in the bumper. There may well be a wiring connector already there for the foglamps. Then its just a case of switch, fuse and relay.
To Philgee.
Yes your right, a multi connector hangs down behind both plates.
Regards, Beagh.
Hi there, is this diagram any help mate post-74463-1254065944_thumb.jpg :thumbsup:
Best regards Pete.
