Hi All
I belive my surf has a lift kit as i have a 1.5/2 inch gap between the chassie and body tub now i want to remove it and put my surf back to normal any body know how the body is fitted to the chassie ? is it justed bolted stright on to the chassie and if so what size bolts are needed?
dom :blink:
Hi All
dom :blink:
thts a body lift you got on there.....the spacer blocks go between the mounting points on the tub and the chassis.....its fitted to give you more clearance for bigger size wheels and therefore more clearance between the axle and the ground...to take it off youll need a set ot standard bolts m10 and m12 i dont know how long as ive got a hilux pick up and the lengths are different to a surf but 60mm -70mm shouldnt be too long.....undo bolts jack up body enough to get the spacers out ..... let down body and rebolt it together using shorter bolts ....make sure the body is square to the chassis before you tighten them up....never been asked how to delift a truck before.....personally id leave the truck as is and put a bigger set of wheels on it
:thumbsup:
