Gen 7 Speedo Removal
Pepperami
Hiya guys
Couldn't see one hence the question
Are there any "HOW TO" guides for removing the Speedo please, I need to find which wire on the back is the PULSE wire or SPEED SIGNAL WIRE as I need to splice into it for the new head unit
Cheers!!
Chris
34 thread views and not one reply :(
I have looked for a thread on the subject and cannot find one hence the post, come on guys someone must know lol
Chris
first remove the black frame, two phillips screws on the top hold this.. you will need a short screw driver as the steering hub will get in the way. Pull the black frame away.
Once you remove that you will see 2 or 3 phillips screws remove them and the speedo cluster is free. I fitted my GPS antenna behind my speedo cluster.
I presume you are fitting a sat nav unit for the speed pulse. When i fitted my HU i spliced into the speed pulse from main internal wiring harness... at the bottom of the centre console near the gear shift.
Its the white wire with pink stripes.. i have the purple wire attached to it in the pic above.
YEAH!!!
M8 your a STAR!!
Thank you :)
Is that picture pretty much what I will see when the centre consoles removed?
Im looking at it, trying to see what connector block thats on, and where its located, I wanna make sure I splice into the right wire lol
Chris
YEAH!!!
M8 your a STAR!!
Thank you :)
Chris
Yep remove the center console and you will have something like this:
Then its the top block.. and the white and pink wire as pictures.. its the only white and pink wire on that connector.
I could possibly get a better pic if you like when i remove my center console this weekend.
If you could take a few pics that would be great!!!
I'm going to do mine this weekend too so perfect timing hehehe
