Gt4 Dumpvalve
licksrpm
hi i have been thinkin of gettin a few breather mods on the go . just wonderd is there anything i have to look for when changing from standard to aftermarket dump valve
You got an induction kit always a nice upgrade to go with a dump valve? I wouldn't say you have to look out for much, you getting a recirculating dv or vent to atmosphere, seems so long ago i fitted a dump valve to my charge cooler? I'm going to be getting an ngr type s dump valve, they sound pretty awesome.
just thought id check and yes its the stanterd top mount cooler . they very easy to fit ?
and i think im losin a tiny bit or water just slightly damp around a bottem seal and is there much in they way of upgradin rads etc
Around the bottom pipe? Rotate the spring clip a bit and see that helps but watch out cause these can leak if not clipped back in their original position. Yeh theres a few rads out there for our car, shouldn;t have a problem getting one, you using water or coolant in your system?
oh right i will have to investigate a litle i thort just the normle rad would take the usual mix water+ coolant if you see what i mean , i shall see if i can try the clips im hoping it wont be nackerd ifso i should think il upgrade only way to go il get there
No that is correct demin water mix with coolant think u misunderstood me ha. How much u thinking of spending on a rad?
what ever it costs mate im mad for my cars so will have to see looks like it could be a job as there seems to be a few radiatiors lol n cheers mate
mate do you know anywhere that sells a bigger core radiators aka upgrade ive been looking mate but cant realy find a whole lot you know any ideas ?
Off the top of my head pace, koyo, asi, there is always some on eBay worth doing some research
I'm using a koyo on my ST205WRC and have to say i'm very impressed with the results it gives. Koyo would be a better radiator than the ASI but the ASI is a big improvement on the standard OEM part.
