Its Going
rav man
Well time has come to wave goodbye the the Rav, i have to say its been a top motor. Its now been replaced by a motorcycle. So a sad day in our house.
I will be sticking a few bits up on the Bay shortly so would appreciate a clue as what you guys (and galls ) think they would be worth.
A set of the roof bars in silver.
and a rear door check strap (from the T180)
Cheers.
RM
A K+N filter (2.2 Diesel) which is only a couple of wheeks old.
Cheers.
RM
Hi RM,
£20.00 for your air filter ,you post to Scotlandshire?
Big Kev.
Sold, Ill send you a PM,
Forgot to mention theres one of those rear bumper protectors (the one thet fastens to the top of the rear bumper to prevent (or cover up) scratches whilst loading.
A set of propper fitted mats too, might aswell get shut rether than hand it in i had to buy it in the first place.
RM
RM
Hi Ravman,
could I have some details of the mats and bumper protector?
Hey fellas.
This is getting kind of like an advert - please communicate by pm!
Hey fellas.
Bit late for that one Anchs..... ;) ;) ;) ;) ;)
Good luck with whatever new vehicle you go with Rav Man
Hey fellas.
Ive got a standard rear checkstrap, free to a good home, think Anchs said they fit the 4.2 if anyone wants it, but check fitment first..
55yr old wife free to a good home (any home really) good cook, Nope can't think of anything else :D
Local.... is that the wife in the avatar sliding off that chair...... Just want to be sure before I make an offer :unsure: :unsure:
Yes it is, but it was taken 35 yrs ago, She's gained a little width + lost a little height since then, but she still slides off chairs occasionally.. :D
Are you sure Local.....
Removing all the photo shop imagery .......
Socond thoughts I'll give it a miss....... :sick: :sick: :sick:
Hey fellas.
Hi Stew, Are you willing to consider a trade-in? Mine is in reasonable shape but has a few more miles on the clock. Oh, and she slides of chairs as well after about a glass and a half of wine! ;)
Hey fellas.
I am willing to consider anything Chris, however i don't think you could afford my wife as it takes at least a litre + a half of wine before she slides off chairs + you'll have a hell of a job getting her back on her feet again :D Stew
I have found that the rear bumper protector for an XT4 (apre on door) will fit on an XTR (no spare) if it is either just positioned inboard about 20mm further or 20mm trimmed off the inner edge. The XT4 bumper is obviously a bit deeper to blend in with the wheel cover. Just for info of those with XTR's as Toyota dont seem to list a similar bumper protector (thick plastic) for that model.
Does anyone know the bore size of the Rav wheels, i know the PCD is 114.3 and the older models are listed as hving a 60mm bore but dont know if this was carried over to the 4.3 models. I ended up with a Suzuki Grand Vitara (new shape) spare wheel which i wondered if i could use as a spare if needed as they use the 114.3 PCD the same and has the bore size at 60mm.
RM
Hey fellas.
Blimey! It would be cheaper to run a Land Cruiser ;)
RM
You need wheels with a PCD (basically the diameter of a circle that passes through the 5 studs) of 114.3mm, an offset of between 35 and 45mm and a bore of 60.1mm
Cheers for that Anchorman so that should fit , i wont advertise it here :naughty: . But it may be of use to XTR owners , so drop me a pm if you want a spare.
Well the main news is that the Rav went today, quite sad to see it go it had been a blinding vehicle , doing everything i had asked of it,
I took most of the accessories off it (and theyve just been sold on the Bay) so got a bit back for them which is good news, i think they were the most sensible ones to have , rear bumper protector, roof bars, T180 check strap, K+n filter, boot liner etc,
I didnt remove the rear tow bar even though i had had requests for it due to having to remove the bumper and the wiring.
Hope to keep poping back in from time to time, (maybe back in the Rav4 fold, again, this is the second time)
Off to play with my other toys now.
:D
Cheers guys.
RM
