Turbo For 4a-fe
MSC_Kev
Turbo Kit
Anyone seen this website?
I have emailed them and they will ship to the UK, what do people think on the turbo set up?
Corolla Superior Turbo Kits Include:
- Garrett T25 Turbo w/ Wastegate
- Cast Exhaust Manifold
- Chrome Heat Shield
- Downpipe w/ Gasket
- Map Unit (Black Box)
- SS Braided lines for Water Cooling
- SS Braided lines for Oiling
- Return Hose and Fittings for Oil to Pan
- All Hoses & Clamps
- All Necessary Hardware & Fittings
- Generic Install Instructions
For Engines: 4AFE (1.6L), 7AFE (1.8L)
Boost: 6 PSI
HP Gain: 30% Increase (safely on stock engine)
Turbo Efficiency: 300+ HP
Direct Bolt-On: Yes
Warranty: 5 Year on Cast, 1 Year Accessories
The kit works out at 1084.86 plus about 400 to ship into the UK :D
Or this one?!
Corolla Extreme Turbo Kits Include:
- 2 Injectors & Interface Block
- Injection Control Unit w/ Turbo Timer
- Blow Off Valve (BOV)
- High Flow Front-Mount Intercooler
- Polished Aluminum Intercooler Piping
- Injector Control System Settings
Boost: 6 PSI
HP Gain: 56% Increase (safely on stock engine)
Direct Bolt-On: Yes
Ball Bearing Upgrade: $400.00
This kit works out 1519.02 and again about 400 to ship it into the UK.
I'm seriously interested in either kit, but I want to do some research on it first and see if it's good value for money etc and also to see if the company seems sound. They have replied to all emails within 48 hours which is good :)
Any thoughts on the above?
thanks
Kev
Make sure that it is for the 4afe not the 4fe mate A friend of mine was looking at a turbo kit for a 4afe but after some calls and e-mails it worked out that there site was full of :censor: and it was for a 4fe not a 4afe like they said on there site!!!!! w :censor: s
joe ill catch you at some point mate on msn!!!!!!!!
ok thanks for that :)
I have been doing some digging and searching out parts for my car and engine and came across it.
They seem very clued up on what there talking about, but as you say you never know until you actually recieved the stuff. I do like the idea of the conversions shown on fensport. However I probably would wait until my current engine has clocked up some miles due it only being 50k old and I wouldn't want to strip out a perfectly good engine
Kev
