2001 Key Adding New Key [sync]
timson
Has anyone got the definitive procedure for an avensis 2001. We have a fully functioning key but the spare went into the washer. Obtained another key and swapped the chip from the washed key into the other key. The key will now start the car but not operate the c/locking. Is there a sequence for adding this key?
Thanks in advance. timson.
All Sorted thanks to Pat Boyle You're a star!
Toyota Avensis July 2000 - 2003
Avensis Verso 2001 - 2006
A total of four remotes can be programmed into the system.
Starting conditions:
- Car unlocked
- Driver's door open
- No key in ignition
Carry out the following within 5 seconds:
Put the key into the ignition and then remove it twice. Do this without turning the ignition on.
Carry out the following within 40 seconds:
Close and open the driver's door twice.
Put the key into the ignition and then remove it. Do this without turning the ignition on.
Put the key into ignition.
Close the driver's door.
Turn the ignition on/off once to program a new remote and keep existing remote(s).
or
Turn the ignition on/off twice to program a new remote and delete existing remote(s).
Remove the key from the ignition.
The central locking should now lock and unlock once to program a new remote and keep existing remote(s).
or
The central locking should now lock and unlock twice to program a new remote and delete existing remote(s).
Carry out the following within 20 seconds:
Avensis - Press the lock button on the remote for at least 1 second.
Avensis Verso - Press the lock and unlock buttons simultaneously on the remote for 1.5 seconds.
Carry out the following within 3 seconds:
The central locking should now lock and unlock once.
If the central locking locks and unlocks twice the sequence has not been successfully.
Open the driver's to complete the sequence.
Regards.
Pat
have got car booked in tomorrow to do this to afraid to do and lose only key on 52 avensis,have seen other posts that say turn key 5 times, open door 6 times. did reprogram a nissan once but took about 5 times and always scared it will lock the only key out about £45 from mr T plus keys from eBay.
