Vacume System Diagram Needed. Fs3e
Posted (edited)
Hi me again,
Anyone know where i can get hold of a vacume system diagram for my carina e 2l 1993.
Thx
I'll tell you y.
I keep getting 3.1 Map sensor on the diagnosis. I changed sensor but still get 3.1, Now the pipe from the sensor goes to a black thing with 2 connectors on it the second pipe runs offf down to the bottom of the engine to another valve with to pipe connectors on it that seems tobe bolted into the powersteering pump. when i take the pipe that comes from the top of the engine off there is no suction but takin the other pipe off there is, so this seems to be where my prob is. BUT how the hell do you take it off the car to check or change it, there just doesnt seem to be enough room.??????????????????????/ & if it is goin into the powersteering pump does fluid come out when the air valve is removed.
Edited by pdrod
