No Water When Rear Washer On
wuly1554
It's the same bottle as for the front wipers. There will pobably be a blockage in the line.
Check the nozzle with a pin to see if there is any crap there. A tool is available to clean the nozzle.
I take it the front jets work?
To remove the rear washer jet do the following, as per the Haynes manual.
Removal
Open the tailgate and, using a screwdriver, carefully prise the tailgate washer jet from it's location & disconnect the washer hose. (At this point I would close the tailgate & try itto see if fluid comes out. If not then the blockage is further back in the system. If the fluid does come out, clean out the jet or replace it.)
To refit it, just reverse the way you took it off.
Hope this helps.
Cheers,
Marv
