Oil Maintance Light On
power
HI ALL I HAVE 56 PLATE AVENSIS D4D 2007 I HAVE CHANGED THE OIL I CAN NOT RE SET THE OIL SERVICE LIGHT THERE SPANNER COME ON SAYS OIL MAINTANCE REQUIRED BUT I HAVE FULLY DONE IT I HAVE NO MANUAL THNKS
press the odo button , turn on the ignition keeping the button pessed you will see 5 segments that will count down to zero, keep the button pressed until you see 6 zeros it is then reset
