Did any one knew about the EP81 starlet 1993 using the 14" or 15" Wheel ?
Any one have the owner manual show it can be use 185/60/R14 ?
thanks
You can fit 5.5/14” PCD 4/100 rims with 165/60 or 65 R14, 175/60 R14 and 185/55 or 60 R14 tires. You can, also put 15" rims with 195/45R15 tires but you may modify the wings of the car.
yep im runing my car on 185 55 14s lowered on coil overs and had to roll the arches on the back all i done is just took the wheel off with it in the air and tap it with a hammer cafully all the way round painted in red hammerite so it doesnt rust and jobs a gooden :)
