Stcking Door Lock
larry yarry
Hi new on here and wondered if anyone had an idea of how to sort this one out.
the central locking unlocks all the doors but the one back one the drivers side which I have to pull up manually if I need to get it open. Feels like its just sticking but Im unsure how to sort this out can anyone help me with a simple solution.
Many thanks
Child locks activated?
No child locks are not on you can physically pull the lock up from the inside but its not unlocking using the central locking.
Many thanks
I would suggest the removal of the affected rear door handle, and panel trim, taking care not to break the various attachment clips, peel back the waterproof membrane, if fitted (depending on model) and inspect the Linkage, and or cables from the CL door actuator unit, to the Lock assembly
one or more of the linkages could have become detached, if so simply re attach, test, and replace the panel and door handle
Also now you have the panel off you can operate the CL to see were the fault is, (is the wiring/Plug attached to the actuator) hopefully its not the actuator, that's the costly bit. Sometimes disconnecting the unit and giving it a Tap, and a squirt of WD40 could work if your feeling lucky
May the Force be with you. Good Luck.
Many thanks
Many thanks will ry that and let you know what it is.
