Well i got my carina e auto 3s fe, starting as it shud now, but once it warms up there is no power there & runs ruff & just dies out. No code showin other than 31. map sensor but i cant for some reason reset the ecu so i have no code showin, just keep gettin code 31 even before i start the engine.
Has anyone got any ideas.
Oh yes just to add. when starting i get the em light untill it warms up then it goes of & the probs start.
On the corolla you remove a fuse marked efi
you have to take out fuse for 10 secs , Should reset ecu.
Could be the same on the carina.
Only an idea
Only an idea
Yes it is the same. but makes no diffo.
Just wish i could source the cause of the problem.
Thx.
