2003 Rav Gearbox
mintor
Hi all can any body tell me is manual gearbox in 2003 mark 2 rav the same as what is in the mark 1 rav as i think i am going to have to change 5 gear shortly found how to change 5 gear in mark 1 rav on forum site, no good if not the same and what parts do i need thanks
The box is different but I believe the process for changing 5th gear is similar and should be possible with the box in situ.
However, there are enough Toyota Technicians looking in that should be able to confirm...................
......guys! Over to you.........
