Gen 5 Rear Wheel Bearings - Abs Rotor Removal
Scots Miss
RE Gen 5 Celica 2 lt GT ST 182 non UK import. 2WD -
Does anyone know how to remove the ABS rotor from the end of the stub shaft on the rear wheels. Both wheel bearings are rumbling I can only get the Toyota part complete at £300 each (ouch)!! A new hub without the ABS rotor from Euro car parts is £38.
I have removed the unit and looked at several manuals on this but I can't see how the ABS sensor rotor is attached to the Axle stub shaft ( 2 WD) it is a very brittle steel and will easily be damaged. Can anyone explain how it is fixed - pressed in, screwed LH or RH into the stub shaft . It must be removed to be able to replace the wheel bearings?
