Rav4 Audio Wiring Diagram
Indica
Hi all,
I'm a bit out of my depth on this. I'm replacing my crappy cassette player from my Rav4 vx 2002 and I need a wiring diagram. Basically, there are a lot more wires in the back of the existing unit compared to the new unit.
I'm getting an auto-electrician to fit the new one but thought I would be pro-active and get all the info he may need prior to fitting the new unit.
Anybody wanting a double din cassette unit with 6cd changer. I was planning just to bin it. But if there is someone there that wants it you would just need to pay for the postage only.
Indica
Hi all,
Indica
Hi Indica,
have you had a look at connects2.com? They have all sorts of adaptor leads for car audio systems. It might well save you a lot of cutting and splicing the existing wiring. I'm sure that there are other companies doing similar kits. One of our contributors, Hoovie, is something of an expert on this. He has not been around a lot lately but you could PM him. Hope this helps.
Hi all,
Indica
Hi Indica,
Hi Indica, I bought a converter from Hallfords for my previous rav, it converts the Toyota plug to a standard ISO type plug which is common on most New stereo's it cost about £20 but it made for an easy refit of the original stereo when it was time to sell the car.
