This May Save You Money
pdrod
Hi, i have a carnia e gli 3sfe.
Recently i have had troubles with it & as yet been unable to cure it, but it is running so much better now. I managed to get hold of a manuel & was reading about the o2 sensor & checking the resistance, which they say if it's between 5-6ohms junk it. well mines was reading 1.7ohms & being short of money thought i would try to clean it just to see what happened, well i soaked it in petrol for a while & used a airhose to blow it out & low & behold the ohms went up to 2.5, OK still not good enough but i just left it soaking then & in the Afternoon of the next day i had a reading of 18.5 ohms, well over what they say. I have not as yet replaced it to see if there is a difference in the running due to the weather, but would think that there is going to be, but i still have to change the air valve on the powersteering unit as i also think that it's not working also. I will keep informed on the out come.
GOOD MOTORING ALL.
