Front Indicators 2001 Avensis
C S Darby
Can anyone help me. I need to change the OSF indicator unit on my 2001 Avensis but don't seem to be able to find any fixings for it. Am I going blonde, or is it that maybe I need to remove the bumper first. A friend suggested removing the inner wheel arch cover but I don't want to do these things if it's not necerssary. Thanks.
It's very simple to remove... You only need a screwdriver to remove it. When the bonnet is open, you can see a litle hole where the actual head light end and side blik starts. Put the scredriver in the hole and push the blinker out.
If i remember correctly, it's explained in the user manual.
yep and with a little bit of wiggling... :D
it will come out
