Heating System Blowing Cold Air
Ryanzo
On my 2000 celica my heating systems blowing cold air while set on hot unless i rev the engine, anyone any ideas what the problem could be?
thermostat could be stuck shut or broken. otherwise it could be the hot/cold selector cable/flap at fault.
Could be worth checking the engine coolant level first.
Thanks for the replies, it turns out I needed a new radiator the water was flying out of it, but it didnt overheat according to the tempeture gauge, Im lucky I caught it when I did otherwise it woulda went bang.
  • 3 years later...
Is the temp control electronically controlled? Contacts may be dirty.
