Fuel Gauge Dead?
rdv123
The fuel gauge on my 99 Avensis only reads empty, it dosen't even twitch when the ignition is turned on. However the low fuel warning light works normally. I assume its the gauge therefore and not the sender. Has anyone changed a fuel gauge, is it difficult to get out
It may be either, but I think it will be the sender unit, as the low fuel light is activated by the switch reaching a certain level which I think is on a seperate micro switch, but I could be mistaken on that score. Perhaps someone else hopefully could shed some light if I'm right or not.
If it is the sender unit. it is not an extremely difficult job to do, but it may be for a novice. The tank needs to be almost empty first off & the fuel pump needs to be removed, before the sender unit can be replaced. If you are not mechanically minded, I would not contemplate attempting it.
If you think you can manage this, let me know & I will write it up when I can for you.
Cheers,
Marv
I am sure the guage is fixed to the speedo.
The old avensis had stick gages
Start the car and tap on the on the plastic sround,
does it move ?
does it move ?
Thanks, do you mean its one unit incorporating the speedo, it is a needle type gauge and I have tried tapping it to no avail.
Cheers,
Marv
Thanks, my first thought was the sender which I changed in our Golf without any problems. I removed the panel under the rear seat and the Avensis looks very similar. Its the fact that the low fuel light still works made me suspect the gauge. I think I need an auto electrician to tell me which unit has failed
Cheers,
Marv
If it was your sender, then your light wont work.
Take the cluster out. and have a look at the PCB.
Mine had this problem just prior to buying it. The garage had to replace the complete instrument cluster form a salvaged car. Not had a problem since (three yrs)
There are 2 on Ebay at the minute. One at £32.40 & one at £30.50. Links for both below
£32.40 one below
http://cgi.ebay.co.uk/Toyota-Avensis-instr...=item27ab5c39bf
£30.50 one below
http://cgi.ebay.co.uk/Toyota-Avensis-dashb...=item2302aaca3a
Thanks guys, looks like gauges then
Or you could try your local breakers for one.
Cheers,
Marv
they for petrol cars...
the needle sticks on the backplate on the cluster assembly but need to be careful
the perspex cover unclips
place a small piece of tape under the needle so you know where it goes back on
gently ease the needle off the guage
get a very hot needle or soldering iron and enlarge the hole around the needle spindle
it doesnt take very much
realign the needle with the tape and gently press back on /not too far
reconnect to the car andit should work like new
it was a common fault on the 97-00 model avensis,
hope this helps
