Wanted - Corolla G6r Rear Hub, Hub Carriers And Calipers
Insanity-74
Seeing as the Corolla has terrible drum brakes I want to convert them to discs so if anyone has the above parts then please let me know....much appreciated.
Nial
does yours have ABS? if not then a better upgrade (though a bit more technical) is the corolla TSport rear setup. it incorperates a drum handbrake and disc foot brake (much like the GT4 setup). its what im running on the rolla.
the disc type handbrake callipers have a habbit of siezing and its near impossible to do handbrake turns (not that im suggesting you would :rolleyes: )
What do you have to do to fit the Tsport brakes to the 98 corolla?
you need to mod the rear tsport back plate and use longer bolts (ive got some of the correct ones). then its just a matter of shiming the caliper out a tad.
the handbrake cable is a bit of a faff but its all do-able
