Wheelspins!
supafly
I know you shouldn't pull wheelspins. But when i do them (rarely), the whole car vibrates. I drove other cars before and that didn't happen.
:thumbsup:
its normally cos the front suspension starts to bounce and hits the bottom limit on the shock therefore causing it to vibrate
I get that on the Trafford Centre carpark cos they use the cheap stuff, will it damage the car?
nah wouldnt have thought so
only if you were doing it loads and all the time :lol:
If u can smell ur clutch cooking then its not realy a good plan lol
that only happens when I make the car bounce up and down, dont do it any more
wel it wont bounce with alot of weight in or in the wet, and its not good for your gearbox too much strain
mine desnt juuder.. just smokes big style... but smokin is bad for your health!
that cos your pushing how much(?) power through the back end! :lol:
no i mean bounce as if it has got hydrolics, the back of the car bounces up and down, has no one done it
Our lass hits the roof and starts to inform me the price of tires, thats the main problem I get with wheelspins!! (oh and dont buy Yokohama 306 s tires, they spin left right and centre).
I actually didn't think this was the suspension.
I have the same problem too as I have to get out of a :censor: horrible juntion each morning.....however it's nice to put the TS's power to some good use.
I find that even without inadvertnetly wheel spinning...that I get a bad judder when aclererating harshly....but it's only usualy when cold. I put it down to the clutch not engaging smoothly.
I would have thought that if it was the suspension...then those wheels must be sure be bouncing about to hit the bump stops, as even with the tigher suspenstion..there's still quite a bit of travel?
Vipes
Im from Mcr
Matched the speed of an Audi A4, had to give up cos I had no road left, his engine was reving louder than mine
