My Efforts At Diagnosing An Electrical Fault
barki
Hi chaps
I have an 03 plate Celica T Sport
The passenger window ranomly stopped working recently
Presing the 'lock window' button/switch only locks/unlocks the doors and does not seem to effect the window,
I first checked the fuses in the drivers footwell - both electric window fuses are fine
Then I looked at the switch itself - seems fine although I don't know how to test it?
Today I took off the passenger door card - all of the connectors are pluged in and the windows runners are nice and greasy.
How can I figure out where the problem lies?
One final point - When you press down the window switch, it doesnt effect the idle speed or light brightness or anything as you'd expect if the motor was drawing loads of current trying to unstick the window. When you press the button nothing at all happens, no noises no nothing, as if its unplugged
Any help would be appreciated!!!
Cheers chaps
p.s I can post pics of the T sport if anyone is interested, or if anyone likes R5GTT's i've had a bunch of those that I have pics of.
Tom
Hi barki
I've got good news for you - There's a very simple fix for your passenger side window problem
If you look at the dashboard, to the right hand side of the steering wheel and just below the dials dimmer knob, there is a button
This button enables/disables the Passenger window, just press it once to egage/disengage it and all should be well again
Please let me know if this fixes your problem
Hope this helps
Unbelievable!
I feel rather stupid now having wasted all that time fannying about trying to fix a problem that didnt exist
Cheers for you help - it worked
Tom
No worries Tom, glad to be of help
I had the same window problem myself after cleaning the dashboard, so you're not the only one who has fell foul of this button
Doh!
  • 9 months later...
Doh!
I've had my 03 plate VVTI for 6 year and NEVER come across this. Have spend the morning check the switch / motor / fuse etc and came to this forum out of desperation.
- Problem sorted - thanks so much for posting this helpful advise - AEV
lol , many many people have done this , including alot of hilux surf owners ,from when i owned one . its canny embarrasing like.
