Change Dispaly After Battery Change
Taffylad
Hi Everyone
Just had to have a new Battery fitted. The display in the centre of the dash has defaulted to KPH / KPG. Can anyone help with advice to change it back to UK Miles measurments
Thank you all
Taffy
..just under the display you have a round button,,in the middle.Push that button once and thet turn right/left the button,in order to get mileage display....Advice:if you keep your fionger on that button,it will turn off the display,,so give a little push!
Hi Taffy,
If yours is the same as mine, you need to press the "TRIP" button till the unit display appears, then push the "MODE" button & the UP & DOWN button till MPG/MPH is displayed.
Then press the "MODE" button to complete it.
Cheers,
Marv
Hi All
D4D2003......... Sorry my friend no middle round button below the display
Thank you Marv :D Got it in one. Thanks very much
Taff
