Celica 190 T Sport
damian1972
HI CAN ANYONE TELL ME WHY IS WHEN I PULL AWAY IN MY CELICA 190 T SPORT 2002 IT MAKE A SLIGHT RATTLE FROM FRONT AND HOW CAN I CURE THE PROBLEM? MANY THANKS DAMIAN
thank you for your reply and reading other posts it sound like the heat shield. what would you suggest to have it done? is it easy to fix or do i need to take it to a garage? many thanks for quick reply
  • 1 year later...
... I have exactly the same problem, did you get it fixed in the end, did it cost much?
The holes on the heat shield tend to wear and the holding bolts come loose. Replace the bolts and use washers to cover the worn holes.
