Starlet Engine Rattle
Hou
Engine really rattles once started,then stops untill mid revs onwards,is this due to it needing the valvee clearances done due to a service?
If you got a 2E engine,the tappets need doing regular to keep them quiet.
You may have a corroded heat shield which vibrates like mad,and I have come across several Starlets where the spark plugs are loose and cause a noise like excessive tappet clearances - just tighten the spark plugs up correctly.
:thumbsup:
