Wing Mirror Replacement
GregP
Hello All,
has anyone removed the wing mirror from their Auris? The bit I am interested in is the power cable that goes inside the door. How do I unplug it? Do I need to remove door plastic cover? Any advice appreciated.
thx
yes, you have to remove the door cover (if you don't know how, ask here); after removal you can find the connector
no need to check; it's very simple
take a flat screwdriver and wrap it's tip in some insulation tape
then take out the small cover behind the handle
remove the grey cover of handle
undo those 3 bolts you can see
remove the panel starting from the bottom
undo the cables
then all the connectors and what you need
Thanks man. I owe you a pint already :)
to remove the panel can I just pull it slightly or do I need to lever up the plastic pins to release them?
first time you pull the cover out starting from the bottom and arround the cover (all the points marked with triangles), then you lift it up (it's hung up on the top)
good luck
